NEWSPAPER – INSTAGRAM PROBLEM
Instagram Gallery Block Render Failed – Tried accessing nonexisting field (comments_count) on node type (Media)
Please let me know what option for Instagram feed you use.
Please try to reconnect the account please make sure that during the authentication process, you connected the Facebook page with the Instagram account connected.
The problem has been occurring for several days.
Ok, but I need more information, like if you use the Instagram from footer template or block Instagram from tagDiv Composer, personal account, or business account.
I use on several sites, in the footer, in the company account, on none of them works.
Please provide the link to your website.
Also, please check this option -> https://i.imgur.com/P9jmyXT.png
I do not use a standard footer, so it should not matter
I’m having the same problem (Instagram Gallery Block Render Failed – Tried accessing nonexisting field (comments_count) on node type (Media)
I also don’t use the Instagram in the footer.
problem has occurred since may 24
@Terra
Adentro From your screenshots I see that you use a personal account.
Please try to change the settings from here save and check after https://i.imgur.com/XWqtDYx.png
@norbiQue
I need some screenshots and the link.
This has also been happening with our Instagram footer; same exact error.
No changes were made in our side and it suddenly stopped working.
After updating WordPress and Newspaper theme the problem persisted. I’d bet this is a change on Instagram’s side that requires a new update for the theme.
https://i.imgur.com/8dQTTAI.png
I solved this way … https://imgur.com/a/8TkAugC
reconfiguring the personal Facebook account and then the business one. Thanks for the support
Tony Cericola
myNews.iT
I’m glad is resolved.
Have a great day!
It wasn’t expired yet, but following the above advice I renewed the token for 60 more days. It’s still not fixed.
Should I create another thread?
We don’t own a business account.
So, do you use a personal account? What version of the theme do you have?
Yes, we have a personal account set up.
Newspaper version is 12.4. As I said before, this started happening suddenly and updating WordPress & Newspaper didn’t work out.
I will do some tests with my personal account. Please let me know if you use the element from Theme Panel -> Footer or the Instagram widget from tagDiv Composer.
we have again the same issue after last update. The Private Account is still connected and not expired, but the Instagram gallery is not shown.
Instead, there is an error: Block Render Failed – Tried accessing nonexisting field (comments_count) on node type (Media)
Best regards, Daniel
same issue here:
https://kitz-magazin.de/
What can I do?
Happy about feedback
Bernd
Did you have tried to disconnect and reconnect the facebook and Instagram accounts?
We use the first one, theme panel’s footer. https://i.imgur.com/IptXBQZ.png
Yes, I disconnected from instagram and reconnected again: still the same failure message.
I used the Element from the TagDiv Composer and defined the page as the footer.
Instagram Element
I have exactly the same problem.
I have not made any changes. Appears: Instagram GalleryBlock Render Failed – Tried accessing nonexisting field (comments_count) on node type (Media)
Exact same problem here. Lastest version of Newspaper. No changes made prior to error occurring. Personal Instagram.
Viewing 25 posts - 1 through 25 (of 38 total)
