I too have the exact same problem that reports this error: Instagram GalleryBlock Render Failed – Tried accessing nonexisting field (comments_count) on node type (Media). I have the latest version of the updated newspaper theme and it’s not working.
I read from previous posts that many people like me have had the exact same problem and that you wrote that some developer was busy finding a solution. At what stage is the research and solution of the problem?
Please edit the file td_instagram.php in this path td-composer/legacy/common/wp_booster/td_instagram.php and remove https://i.imgur.com/Mg9DE3w.png “comments_count,like_count” line 655
Also experiencing this on our website.
Using Instagram Personal account.
Getting a Block Render Failed – Tried accessing nonexisting field (comments_count) on node type (Media) error.
Tried disconnecting and reconnecting same issue. Confirmed it’s logged in and linked. Says there are 45 days left on the token.
Is there an ETA on a resolution?
Hello Anamaria can you explain what you mean by the link above as im having the exact same problem and nothing is seeming to fix it. Thought there is no point in creating a new thread when the question is already here. How do I edit the file td_instagram.php thanks
Oh that’s great so when the new update is out next week it will automatically fix the problem and we will be able to display the instagram feed again? Thank you I will wait for the update 🙂
You can update now the theme. Before please make a full backup to all files and the database, in case something goes wrong. => https://forum.tagdiv.com/how-to-update-the-theme-2/
