I have upgrade the theme from 10.3.2 to 10.3.3.
During the process I received this email
Since WordPress 5.2 there is a built-in feature that detects when a plugin or theme causes a fatal error on your site, and notifies you with this automated email.
In this case, WordPress caught an error with one of your plugins, tagDiv Cloud Library.
First, visit your website (https://www.ciscozine.com/) and check for any visible issues. Next, visit the page where the error was caught (https://www.ciscozine.com/wp-admin/update.php?action=update-selected-themes&themes=Newspaper&_wpnonce=xxxxx) and check for any visible issues.
Please contact your host for assistance with investigating this issue further.
If your site appears broken and you can’t access your dashboard normally, WordPress now has a special “recovery mode”. This lets you safely login to your dashboard and investigate further.
To keep your site safe, this link will expire in 1 day. Don’t worry about that, though: a new link will be emailed to you if the error occurs again after it expires.
When seeking help with this issue, you may be asked for some of the following information:
WordPress version 5.4.1
Current theme: Newspaper (version 10.3.3)
Current plugin: tagDiv Cloud Library (version 1.4 | built on 01.04.2020 8:57)
PHP version 7.2.30
Error Details
An error of type E_COMPILE_ERROR was caused in line 1358 of the file /ciscozine.com/public_html/wp-content/plugins/td-cloud-library/includes/tdb_functions.php. Error message: require_once(): Failed opening required ‘tdb_template_import.php’ (include_path=’.:/usr/local/php72/lib/php’)
Why? What can I do?
Fabio
If the problem still persists and you get other emails from WordPress let us know!
Hi Calin,
I have a strange behaviour. You can read the post here: https://forum.tagdiv.com/topic/createedit-post-mobile-view-on-desktop-why/
thanks
