I am looking to update our Newspaper 6 to 7 and it is asking me to remove 6 and to upload 7. Last time i did that (from 4 to 6) I had to remove 4 and then upload 6 before spending a good few hours customising the site so it resembles the previous site. Is there a way to get round this? I want to update it to Newspaper 7 but I am trying to find a way of not having to redo the sites customisation. Is there a way to update without removing the current design of the site? I hope someone can help and give me some good news that will make the whole process easier.
Many thanks in advance.
-Muchaneta
Updating from 4 to 6 was a huge leap. The change from 6 to 7 should work fine because you are already using the Redux Framework backend.
I used sFTP and uploaded over the files currently on the site but always have a backup in case something goes wrong. Here’s a proper way:
Put the site in maintenance mode (https://wordpress.org/plugins/simple-maintenance-mode/).
Use Filezilla (https://filezilla-project.org/) to connect to your server.
Download the current wp-content/themes/Newspaper folder to an archive location. Don’t overwrite the new version.
Using Filezilla, rename the online directory Newspaper to Newspaper6.
Upload the Newspaper 7 to wp-content/themes/Newspaper
Log into WordPress
Take site out of maintenance mode
Enter Theme Panel and check settings.
Save as necessary.
Good luck !
LPH.
Hello Mucha K,
Before each update, we recommend doing a full backup to your data because in this case you will avoid losing all your data. Please keep in mind that the updating from 6 to 7 it is not comparable with the updating from 4 to 6. If you are custom modification through the code and you are not using the child theme, please keep in mind that all of them will be overwritten by the new update. For more information about what type of files were changed in our new update, please check this link ->changelog section -> http://themeforest.net/item/newspaper/5489609 Please notice that your update has to be done only via FTP because this is the surest method in this regard. For more information about theme updating, please check this documentation here -> https://forum.tagdiv.com/how-to-update-the-theme-2/
Hope this helps!
Good luck with your project!
