Newspaper child theme problem with td_module.php
I’m implementing the Co-authors plus plugin with NewsPaper theme by creating a child theme.
It seems td_module.php can’t be overwritten in a child theme.
Are there any workarounds?
Indeed that file cannot be modified in a child theme, you would have to modify the file in the main theme. Maybe make a backup of it after you modify it and replace the new one after an update.
TD composer is not working. I add the element “Title with Text”
And when I try to add content by clicking “Edit content” a popup opens for WP Editor
But the problem is when I enter the text in that box it doesn’t reflect on the website.
Please let me know what the issue is as I have deactivated all the plugins and deleted all cache and everything and still it’s the same
@Aman
Singh You could have opened a new topic with this problem.
Did the problem occur before or stated happening after a recent event? Does it happen if you try in a new page? What if you try with other text elements? Also what theme version are you using?
Are there enough resources? – https://forum.tagdiv.com/requirements-for-newspaper/
Let us know.
Hey,
I have send you the login details on the support email address
The theme version is latest and resources is perfect as per Theme system status
Also it happens for all the pages existing or new both
Please help me fix it and do check the mail for login details
Thank you
