I recently attempted to install Newspaper on our site, and while the installation appeared to be successful, the theme management pages don’t work. So, the theme installed, but when the theme activates instead of going to the Welcome page, I get an HTTP 500 error. This is the case for all theme admin pages: td_theme_welcome; td_theme_plugins; td_theme_demos; td_theme_support; td_system_status; td_theme_panel. I never got the option to activate additional plugins, though the theme did install the tagDiv Composer and Social Counter plugins on its own. Running latest version of WordPress 5.1 and did a new install of the latest version of Newspaper.
We did have an older version of Newspaper previously installed, but not active. I removed the old version, as well as the associated plugins, and I’m not sure why I’m unable to get into the theme itself once it’s activated.
Installed theme and activated. As well as installed default demo. But all the pages & posts were updated. But homepage not properly loaded similar as demo.
Please look on the url.
http://www.meetkansascity.com/wordpress
admin/admin@123
try to install TagDiv Cloud Library, site throw internal server error (500).
So please check this url.
http://www.meetkansascity.com/wp
admin/admin@123
@roobanyadav Seems there is a problem there, please check the theme requirements guide carefully – https://forum.tagdiv.com/requirements-for-newspaper/
Check the theme system status parameters, increase the wp-memory to 256M if possible, also the other parameters as mentioned in the guide. Also activate the necessary PHP modules, if needed contact the hosting provider for assistance in doing this.
@marketersclub Please try the same suggestions if your problem is similar. In most cases 500 errors are caused by low wp-memory.
Let us know.
