I am using the Newspaper theme. I have a problem with translating the footer using the Polylang Pro plugin. The site uses a ready-made template downloaded from the cloud (FreeNews) and is in two language versions – Polish and English. I can’t set separate translations for each language, because the footer is the same for the Polish and English versions. Is it even possible to do this with this plugin? If not, do I need to switch to WPML? Is it then possible to set it up?
Przemek
This plugin is not tested 100% with the theme. I think that you need to import a template individually for each language -> https://polylang.pro/doc/strings-translation/
Thanks for the answer, but what do you mean by writing ” import a template individually for each language”. How should I do it in this Newspaper theme? And does the WPML plugin allow to have two language versions of the footer without any problem?
You can duplicate the footer template, but you need to have a different template for each language.
Yes, you can use the WPML. Please check this topic https://forum.tagdiv.com/topic/issues-with-rtl/
I don’t quite understand. How do I assign a different template for each language using Polylang? Where in the Newspaper panel do I do this? Also, would you suggest how I can then duplicate this footer template to get the result I’m interested in, i.e. separate footers for each language?
I don’t know exaclty how this plugin works. I recommend buying WPML and follow the steps from the topic provided above and this guide https://forum.tagdiv.com/using-theme-translations-together-wpml/
