Newspaper theme footer issue on mobile view
When I am looking at the web view on footer, here I am seeing the footer-gossip theme but i am seeing on mobile view its visible footer default pro theme. I want to show mobile view footer-gossip theme please help me what will be the solution.
here are image link –
https://ibb.co/0ysZrB1
jeewan
If you created the mobile pages with TagDiv Composer, then when you install Mobile Theme plugin, your pages will be overwritten by the plugin.
The Mobile Theme is a performance optimized theme included in the Newspaper main theme and it loads only for mobile devices. It comes with it’s own templates for page, post, category, etc so your current templates from the desktop theme will get converted to the mobile theme layout. For more details, please take a look here: https://forum.tagdiv.com/the-mobile-theme/
Better deactivate the plugin and see the results.
If you don’t use Mobile theme, then you can create a header/footer for the mobile page, or convert the header/footer from desktop like this: https://www.screencast.com/t/dDe4WoCd ; then after convert you can modify them with TagDiv Composer.
Hope that helps you!
Thank you Bettina
My problem solved
Hello @Jeewan!
I’m glad you have managed to solve the issue.
Let me know if you need further assistance.
Have a nice day!
