I’m using Newspaper X Header Template Default PRO.
I’ve tried to set up the weather widget by the documentation (https://forum.tagdiv.com/weather-widget/)
Although at the Header section of the Theme panel there is now Top Bar section.
I can’t find the weather widget section at all.
Also I’ve tried to translate the “Sign in / Join”, loaded the translation, saved it still it displays in English.
One other thing that I tried is to disable the “Sign in / Join” with “SHOW SIGN IN / JOIN” button but its still there.
Let me know please thanks.
Attila
Hello !
In the header section in theme panel you will be able to add this as you can see here: https://www.screencast.com/t/4i0L2drOS
If the changes you make ( which the procedure is corect in your case ) and they are not displayed you will have to clear your cache.
Okay let me make this clear.
These options are missing from my Themepanel – Header section.
Its just not there.
The screenshot you’ve sent me I don’t have any of those sections such as:
Select the top menu, Show Social icons, Show date, Date format, Javascript date, Show weather, APi Key, Location, Units.
Here is a screenshot of my Themepanel – Header section:
