Newspapper custom taxonomies filter URL problem
Helllo all,
I am trying to add custom taxonomie for a post, but for some reason when the filters are added and when you try to select a filter the URL becomes: ?tdb_tax_free-or-paid=resource-free and its not working how its supposed to be but if I change the URL to: free-or-paid/resource-free/ it is working, but it seems I cannot change the settings of the Flex Loop Filters. What am I doing wrong ?
Hello @sotirow96!
Check this guide: https://forum.tagdiv.com/filters-sorting-taxonomies/
I hope that helps you!
I checked it already, it does not work, I do not know why the URL’s wont work as they supposed to be. Am I missing something in ACF ? or in template ? I checked everything and I cannot see a problem.
Hello @sotirow96!
We would like to investigate this issue.
– admin url and credentials
That is on a localhost.. is there something specific I am missing when creating my own post type and taxonomies and adding the filter block ?
Screenshot
  • This reply was modified 2 years by sotirow96.
Hello @sotirow96!
Set your taxonomies like this: https://app.screencast.com/suQRU09dbm7Dm
If the issue is still there, then please check if there is not a plugin conflict.
Hello, already tried this, but no effect.
Screenshot
There is no plugin conflict because the ones that are default from when I imported the demo are working but the ones I made are not.. what am I missing ?
Hello @sotirow96!
They should work. Please check that all the settings are the same as the original ones. Verify the settings you’ve applied for those taxonomies. Clear all your cache.
Everything is done, they still do not work.
Hello @sotirow96!
I think it would be better if you could take the project with duplicator plugin and make a staging so we can check your issues from there. I need more information about this situation. Also, check the rule for your field group to be equal to Resources, for example: https://app.screencast.com/S08n3HQiJ3oE5
Everything is set up how it is supposed to be, still the same result.
Edit: I removed the block and added it again and, it was still not working so I switched off “Multi” then saved and now its working. I guess multi does not work.
Hello @sotirow96!
I’ve tested on my end, and it is working as it should in the latest version.
