if I add “<!–nextpage–>” in the source code of my website the page does not get split! I ssee the two pge buttons at the end of the post but the post shows up in both pages with its full content.
Any idea what breaks this function?
Would be great to have a solution.
Hello !
Unfortunately your website is unreachable. You can set the pagination on post loops using tagDiv Composer as you can see here: https://www.screencast.com/t/YwSXTWTGkaK
Dear Vlad,
this is not what I was looking for! I want to split a post (sic!) so that the post appears on two or more pages. If I use the page break button the post page still is rendered as one page (full content not split content over two or more pages).
Do you see a solution to that? Or is it a bug in Newspaper?#
Kind regards,
Martin
Hello !
That is not a bug. That option can be achieved only by creating a smartlist: https://forum.tagdiv.com/smart-lists/
Thank you for your understanding !
Okay, any explanation for that behaviour – or why TagDiv does not support this “standard”?
Hi Vlad,
According to this Info here:
https://forum.tagdiv.com/posts-with-pagination/
the pagination should work!? Is this documentation wrong?
Kind regards, Martin
Hello !
Sorry for misunderstanding !
This option will work but please note that you will need to use the custom html block and the next page must be inserted there: https://www.screencast.com/t/LI3jn3Gd2
Hi Vlad,
no prob! I tried your suggestion but still it does not work. What I get is a pagination box at the end of the page ([1] [2]). But the post itself is shown fully! Also if I click the two page links, the correct page number is bold – but the whole article is shown…
Any idea where to look out for what breaks the intended behaviour?
Kind regards,
Martin
Dear Vlad,
thanks for hinting at “check the plugins” (a standard…). I found out that “Toolset Blocks” does cause this issue. I also will call the support of Toolset to question if they know why the plugin breaks the “nextpage”-functionality…
