"No post" problem after adding slide
I could not use even free sliders of Revolution slider. its wants to get premium member. Anyway i find another plugin and its useful for dekstop. But the problem is that my mobile theme had a row under logo. It a writing “No post.” how I can move this from on mobile theme. Thanks for your help.
My web site is elazigdavetiye.net
There are a few sliders provided in the theme package for the revolution slider
https://www.screencast.com/t/49BKNTGh
https://forum.tagdiv.com/import-revolution-sliders-on-demos/
Regarding the other issue, the mobile theme front page will try to display a post grid at the top. The posts that are displayed there will be picked from the “Featured” category
https://forum.tagdiv.com/featured-posts-2/
If there are no posts in the mentioned category, the grid will be empty. So add posts to the Featured category (created by default).
Or disable the optional mobile plugin and display the same content from desktop. It all depends on your choice.
