I recently bought Newspaper theme and while I like it there are 2 problems I am facing:-
1. I am not able to delete the empty columns which keep piling up. I saw similar posts on the forum but none of the solutions works for me. There is no right click or drag and drop option that appears. Neither is there a delete button when i click on the row.
2. My mobile theme shows on desktop and vice versa randomly. It lasts for few minutes and is a minor irritant but can be awkward for site visitors at times. I can’t do anything with cache as my site is on wordpress.com and they have their own caching mechanism.
Please help. I had mentioned the second problem within a similar topic yesterday but haven’t heard from anyone till now. My site is sabysworld.com.
1. If you select the row and hit the delete key from your keyboard, then it should work. Please note that an individual column you can not delete it.
2. This situation appear when you are using the mobile theme plugin and the cache that you have does not feature options for a separate mobile theme plugin therefore do not know when to deliver the mobile version and when to deliver the desktop version.
We tested with our theme the WP Super Cache and with the settings from our guide this is working correctly: https://forum.tagdiv.com/cache-plugin-install-and-configure/
Hope that helps you!
If you have a problem with your cache, then you need first to solve that problem.
