Whenever I go to Cloud Templates and click on New, I get an error message that says: “Invalid reply from server endpoint.”
I want to be able to use widgets in the footer but can’t figure out how to do that using the current template I’m using. The site is http://daddyhooding.com.
I’m not sure that I did. If anything I use the default settings?
Hello !
Please send us a screenshot of your System Status Tab and make sure that all the requirements are met as you can see here: https://forum.tagdiv.com/requirements-for-newspaper/ ; You will have to first start looking for a plugin conflict. please deactivate ALL plugins except tagDiv ones, also if you are using child theme or cache plugin, deactivate them, clear all cache and try again.
Also you can try and remove and re-install the tagDiv Composer plugin.
Let us know the results.
