What exactly is not working, are there problems with the theme panel? Please check if the theme requirement are met
Also try to temporarily deactivate all non-theme plugins and try again.
If the problem is that the theme panel does not save your settings, in most cases these are the most common causes
– https://forum.tagdiv.com/topic/theme-panel-9/
