https://staging.secretabudhabi.ae/
https://pagespeed.web.dev/analysis/https-staging-secretabudhabi-ae/z72awr0qg6?form_factor=desktop
why the performance is very bad, can you help to improve?
When I tried to install the template, it’s not recognizing my code or I paid that. So I need your help to fix it
Hi djony620,
There will be a need to make the improvements for the list provided on the Pagespeed test.
Also, for speed, if you are using the WP Super Cache plugin, make sure that you also use the Autoptimize plugin and CDN . There are also other cache plugins that can be used to do both caching and optimizing the site, so there is no need to have 2 plugins. For example, one of the best is WP Rocket, but you can also use free plugins like WP Optimizer, Litespeed.
Hi MarcyGaboma, unfortunately, I do not understand the problem you are facing. Could you please provide some more details and maybe some screenshots?
