Pagespeed: WP Rocket or Tagdiv Speed Booster?
what would you say is the best solution to improve the speed of the Newsmag theme – WP Rocket or the Speed Booster Plugin?
Will vary by how your site is setup.
Why not try them to see which works best for you.
The tag div booster is designed to move various things … Including custom theme stuff … To best place for speed. So one click to see if it helps or not. One click to disable.
We use it along with mod pagespeed.
  • This reply was modified 11 years by simchris.
WP Rocket is a caching plugin. Also does minification. Not free.
TagDiv speed booster simply moves JS/CSS elements to the best place (e.g., head or foot). Free, included with theme. Does not do minification.
Not really apples to apples.
For the theme demo, they use W3 cache without minification, just page caching on, as well as the TagDiv booster. As noted in the theme docs.
You might try that first. Or, spend the $39 and report back on how it went! (curious!). 🙂
WP Rocket ‘s the best , at least for me and for my page . I tried all possibilities , but in the end I found that the best Rocket something for my page ( http://www.football-eu.com )
Chris S you start to giving me false and stupid answers , I know you want to help and intention was good , but sometimes it is better to have mentioned something and you’ll be smarter , none of us can know everything and every question that you either have the answer. There are people here who are authorized to suport , let’s cut a little experience , many will you be here for Thanksgiving .
I hope you understand this only as advice not to get angry . Thank you.
Sry. for my BED English (Google)
http://urbanmusichq.co/
I use the tagdiv booster and WP Super Cache (use to use W3 but too many useless options haha)
I test 97/90 or so on my gtmetrix and pagespeed I am pretty sure.
Also use Chris’s optimizations.
@Ljubi B.
not sure what you mean?
You haven’t posted any topics to this forum, so not sure what “false and stupid” answers I’ve given you? I think over the past 14-15 months I’ve provided more helpful answers than anyone on the TagDiv forums.
However, your mileage may vary, as always.
Sorry if I didn’t help you. Free advice is just that.
My answer to your question on the hit counter, for Newspaper, for example, was neither stupid or wrong.
My answer to why your theme panel didn’t have responsive option in Newspaper after the 4x update was correct, as you had not read the changelog to see that responsive option has been removed.
Also, one of your support posts was:
Heeeeeeeeeeeeeeeeeeeeee?
So… not sure what you’re on about. I’ll try not to help you at all in future, since it’s unwanted. Not mad, just perplexed.
In the context of this thread, WP Rocket and TagDiv Speed Booster are two totally different things, hence my response and observation, and answer based on my own experience. I have not used WP Rocket, due to problems I’ve seen with other folks using it, and also because we can run most of those optimizations ourselves running our own server, so don’t need a commercial plugin for that.
So, the “what do you think is best” answer to THIS THREAD, isn’t the same for everybody. “The best” may vary by server and how much time one wishes to mess with things.
Cheers. Sorry to anybody who thinks my help is “stupid or false.” 🙂 I’ll try to cut back on that.
I am currently using WP Rocket and Speed Booster plugin with Cloudflare at the same time and 1 second load time.
http://www.awesomebryner.com
Speed
I use WP Rocket here: https://www.amuzly.com
Don’t run behind speed scores. Scores are just a measure of the fact that “you’re using the guidelines or not.” Make your sites really fast, not just for PageSpeed or GT Metrix. They don’t even record the load time!
I use WP Rocket here: http://www.techfalls.com/
I’m not happy with page speed. I tried WP Super Cache. That was not so bad. But i really hate w3 total cache. So many options. I think that increase page load time instead of improving. Anyway, I have compared other sites with mine. These are http://www.awesomebryner.com who used WP Rocket and Speed Booster plugin and http://urbanmusichq.co/ who used wp super cache with tagdiv speed booster. So here is the result: https://gtmetrix.com/compare/XfrAouTn/kqO8HAk7/vyUNl0r5
Screenshot
  • This reply was modified 10 years by hkhasib.
Try the combination of “Gator Cache” and “Autoptimize”…my site is running like hell. 😉
I use WP Rocket. It’s very good.
@Ljubi B. You site seems so fast. I also use WP Rocket. Do you any other plugin to boost speed?
Please check our documentation for more useful information in page speed regard: https://forum.tagdiv.com/how-to-make-the-site-faster/ Also you can check this topic, there are some useful information regarding Speed Booster usage: https://forum.tagdiv.com/topic/speed-booster-questions/
Hope this help.
Wp Rocket works best for me.
