Picture resolution problem
Hi, i use the default demo layout, and with td_composer i organaized the home page block using the block 15 style. If i put a medium size picture i see good on the preview of the article but after when i read the article (i use the post template style 6) the image is blurred, i need to have in focus image in the preview and in the post, how i can do it? there’s a way to choose 2 different size image? or there are a resolution to adopt? thanks
Hello frau,
Please provide your website URL and some screen captures with those images so I can identify them. Ensure that you are using bigger images as quality (HD for example) if you want to achieve good results and also, check if you use thumbnails to your images from Theme panel. Also, if you are using some plugins for optimizations you should remove all of them because you may appear some unknown issues caused by them.
for the post in the main article in the horizontal bar i use the same resolution 216×150, but when the sam post go in the right sidebar are resized becouse are more bigger… so i used the resolution of 432×300.. but which is the best resolution to use?
thanks
Hello frau1983,
Provide your website URL and some useful screenshots so I will be able to investigate it closer and also, so I will be able to provide a more accurate response. Before this, you should disable all of the untested plugins because this is the first step in WordPress debugging.
http://www.ilmondodifrau.it/ the first post in cinema is mirai, the picture are 432×300, if 216×150 become bad when go in sidebar
Try and use bigger images in size, then the thumbnails will be of better quality. Also the results in the post pages will be better for certain post templates where a bigger image is displayed.
So no need to use different images, use only one bigger in size. The theme will create thumbnails from it to display in blocks and grids
– https://forum.tagdiv.com/theme-thumbs/
– https://forum.tagdiv.com/thumbnails-vs-featured-image-size/
ok but which is the better resolution? you dont know the image resolution to use? The img must have a bigger resolution but i need the image size becouse if is not to the perfect rate will be cut and not show propely..
You could experiment with different image sizes until you identify the perfect results. It will indeed be dependent on image aspect ratio as well and modules used. The thumbnails the theme creates are cropped center top
– https://forum.tagdiv.com/featured-image/
As a note, using flex blocks or flex grids may be easier to manipulate the images in pages. You can choose a size for the image and align it
– https://www.screencast.com/t/nT4OfTw3
