Pinning a post to top of block
Is there an easy way to pin particular posts to the top of a flex block? I am using a “flex 1” style block with no category filter and “latest” in the order. However, I want the option to pin a particular story at the top as we see fit and then have the latest appear below that. There is a “stick at top of blog” setting in the vanilla WP post editor but it seems to not affect the Newspaper flex block module.
You can pin posts by writing their ID here: https://prnt.sc/T8nYbP9csdZJ So, always display the same post.
Also, you can use the feature offset: https://forum.tagdiv.com/offset-feature/
Unfortunately, you cannot display only the first post “pinned” and the rest in the same element.
