Playlist problem
If the title of the video have Russian symbols, the video playlist (youtube) does not appear
Please update your theme if you are not using the latest version 1.6 use this guide(FTP method): https://forum.tagdiv.com/how-to-update-theme/ also plugins that come with the theme files from /plugins folder.
If you don’t want to update your theme try this solution: https://forum.tagdiv.com/topic/youtube-video-playlist-is-not-working/
I’m using version 1.6
If I add to playlist video with Cyrillic characters, the playlist does not work
Example: aW6NXPHI_k8, FHqk4sn4yg0, 1KgD9r8yguo
http://tripsphere.ru/
I also tested this with last theme version and found no issues: http://screencast.com/t/DLQZP6atV and should work also in your case.
Please edit playlist file and see if you have the code like this: http://screencast.com/t/pkEkEHDlk
Please deactivate all plugins, leave only Visual Composer active, also empty cache an try again. Maybe it is a plugin conflict.
I tested this also in playlist on post: http://screencast.com/t/cKRQBYTNt – http://screencast.com/t/WRKumtCvnKw
