Hi. please Help for Customization. I want to move content on post to center position, move widget to right hand more. And Reduce the gap between content and widget.
IDEA >> https://drive.google.com/file/d/1PgaKVnCncopLEjq-HpUqw4-ERa9Z4sk8/view?usp=sharing
My post >> https://www.thelivinginside.com/en/siam-sindhorn-partnered-kempinski/
Thank you
Use a cloud post template, design it the way you want with the tagDiv composer
– https://forum.tagdiv.com/tagdiv-cloud-library-plugin/
Here you can see cloud post templates designed by us, you can preview and even edit them
– https://affiliate.tagdiv.com/#/load/Single
Each one can be imported and used, or you can create your own by using the blank template.
