I AM NOT USING ANY CACHE PLUGIN BUT ONLY Cloudflare SERVICE FOR CACHING. HERE IS MY SITE:
https://www.hospitality-school.com/
My homepage version for mobile and desktop are different. But time to time I am seeing mobile version while visting from laptop or pc. What’s the solution? I have enabled mobile theme plugin but not amp.
This is my cloud template settings: https://tinyurl.com/24xcq6os
This is how I set my desktop version to be visible through cloud template: https://tinyurl.com/2cnehzgx
and the mobile version: https://tinyurl.com/2b73ohv7
But EVERY NOW AND THEN I AM SEEING THIS MOBILE VERSION IN DESKTOP. WHAT’S THE SOLUTION. WHY IT CANT PROPERLY DELIVER PROPER VERSION FOR PROPER DEVICES?
This topic was modified 2 years by
hospitality-school.
hospitality-school.
hospitality-school.
IS THERE ANY BENEFIT OF USING MOBILE THEME PLUGIN? WHAT IF I COMPLETLY DISABLE IT SINCE I HAVE MADE SPECIFIC HOME AND POSTS AND PAGES FOR THE MOBILE DEVICES FROM CLOUD TEMPLATE? I AM GUESSING THAT MOBILE THEME PLUGIN IS THE MAIN CULPRIT HERE. WHAT DO YOU THINK?
This reply was modified 2 years by
hospitality-school.
hospitality-school.
Using our theme you can choose from 3 mobile versions
-> mobile responsive => https://www.screencast.com/t/oJ2ShOp47
-> mobile theme plugin => https://forum.tagdiv.com/the-mobile-theme/
-> mobile page => https://tagdiv.com/newspaper-10-3-7-update-brings-customizable-and-fast-mobile-pages/
If you created the mobile pages with tagDiv Composer, then when you install the Mobile Theme plugin, your pages will be overwritten by the plugin (the mobile theme comes with its templates for page, post, category, etc so your current templates from the desktop theme will get converted to the mobile theme layout, the page content is made without builders in mobile editor => https://www.screencast.com/t/xbgZG8kH also, the options that are provided to edit the mobile theme version are limited (this keeps the things simple)).
This is a video about Responsive Newspaper Theme, AMP & Mobile Theme, Mobile Pages & Templates -> https://www.youtube.com/watch?v=SpGkOnJeNZY
So, the mobile responsive is what you see then that you select the viewport on phone => https://www.screencast.com/t/matV17hH, so some settings may apply for each viewport(where is the border blue), and others are not(where the border is black).
The mobile page has the mobile templates from Cloud Library => https://www.screencast.com/t/YCcZ8rL8
Mobile responsive version of the theme and the mobile page editor can be edit with tagDiv Composer, the mobile theme plugin not.
For example, you can have the mobile theme plugin activate and use the mobile page/mobile responsive version for the homepage/pages, but for the categories pages/404 page you can’t use the mobile page/mobile responsive version if you have the mobile theme plugin activate.
So, if you want to design the pages with tagDiv Composer, you can use the mobile page or mobile responsive version.
Better deactivate the mobile theme plugin and see the results, and assign the mobile page for page, like this => https://www.screencast.com/t/lektAhyjd
Also, clear your cache.
