Please help serious issue with wpbooster
I see a number of people have had this issue with version 6.7 without any resolution.
wp booster error:
Missing parameter: ‘file’
wp booster error:
Missing module: td_module_search
How can I disable wp booster, surely there must be a way to resolve this issue.
  • This topic was modified 10 years by puirseal.
You cannot disable wp booster. People get this error when the update is not done properly or they have custom modifications made.
Please make a clean install of the new version by following this guide: https://forum.tagdiv.com/install-via-ftp/
Please restore all modifications you made to the theme, and switch to the main theme if you use a child theme.
You can also set your search template from the theme paenl. Simply change the settings here and hit the save button: http://screencast.com/t/hH65D9slczNW
Let us know how it goes.
I get this error only on the Crypto News theme,
wp_booster error:
td_api_base::mark_used_on_page : a component with the ID: tdm_header_style_3 is not set.
/home/befame79/public_html/worldcryptofeed.com/feedly/wp-content/themes/Newspaper/includes/wp_booster/td_api.php
Any Idea why?
Me too: http://www.tombraideritaly.it
Thank you
Please install the multi-purpose plugin and make sure the header is set to multi-purpose style 3.
It doesn’t work.
Thank you
Please first make sure the multi-purpose plugin is installed and active
– https://www.screencast.com/t/XGMUaWQcC7
That issue would happen if you install a demo which uses multi-purpose elements, and the required plugin is not active. That demo uses multi-purpose header style 3, and that error will appear if the plugin is not active
– https://www.screencast.com/t/IykBllSkwLyN
