Poor Blog Speed with Newspaper Theme
After thorough checking of the theme documentation and applying all the necessary site speed requirements including the cache, the mobile speed is still poor in loading. Google Page Insight is 27% with Mobile
Hello !
Please provide a link to your website in order to inspect.
Thank Vlad S.
Here is my url link – https://www.paulgeek.com.ng
From what I can see the stile is not loading on your website -> https://i.imgur.com/IShYBK3.png
Please make sure that you do not have a plugin conflict, please deactivate ALL plugins except tagDiv Composer, also if you are using child theme or cache plugin, deactivate them, clear all cache and try again.
Also from what I can see you have some errors in consoles that need to be fix! -> https://i.imgur.com/Cozqa6m.png
