Popular 7 day posts not showing an actual popular post..
When I choose popular 7 day post the post that are showing in the block is not the one that get the most views in 7 days.
First of all note that this sorting option will not work with caching
– https://forum.tagdiv.com/7-days-post-sorting/
If you don’t use caching, then it would work. First activate the setting in the theme panel as the guide suggests. Choose the sorting method for the elements you want. Make sure post views are active
– https://www.screencast.com/t/fnznXYDJ2
The moment you activate the theme panel 7 days setting, the count will begin. Posts with most views will be displayed in the block. Check if the post view count works, each time the post page is refreshed for example, the views should increase.
I use caching so I think this wont work for me, I tried jetpack but it make my host server CPU overload. Do you have any option for me to use some kind of popular posts other than 7 days and jetpack?
Use the simple popular sorting – https://www.screencast.com/t/j8ixs2zguT
Posts with the most views will appear in the block. Be sure to activate this setting if you use caching
– https://forum.tagdiv.com/ajax-view-count/
