Hi, how to get rid of this, please.
Screen shot below:
https://pasteboard.co/He9Ev8h.png
p.s: why don’t just allow users to upload screenshots here??!!
You can disable the sidebar for posts globally – https://www.screencast.com/t/Igb8R3Ki or in each of the post edit page – https://www.screencast.com/t/QPUQHNNsEuH It is the same for category pages, you can remove the sidebar in general – https://www.screencast.com/t/J6aFHZrN and also per category – https://www.screencast.com/t/zO8NLfqyFK6
:(I did it, but it disabled the sidebar of the published posts,I didn’t want that.
i mean I want to get rid of it only inside the post creation (backend) i can’t focus on writing the post! … not from the published post! please take a look at my screenshot to understand what i want to get rid of.
Read this topic:
How can I remove sidebar divider from my tinymce editor: https://forum.tagdiv.com/topic/how-can-i-remove-sidebar-divider-from-my-tinymce-editor-it-is-taking-half-the/
Have you carefully read the link I gave you?
https://www.screencast.com/t/7NU4jsu7G06
In my opinion, the screenshot everything is clear.
You need to delete the code marked on the screenshot in the file editor-style.css, which is located in the themes folder of Newspaper.
Also keep in mind please:
You could make a backup of the modified file, and after updating the theme replace the file with the modified one. Or check to see if this file can be overridden by a child theme.
Child theme support: https://forum.tagdiv.com/the-child-theme-support-tutorial/
