I’m trying to use the “watches store” single template that i uploaded using the cloud feature.
When I was in the post, I clicked “edit with tagdiv composer” in order to change the appearence. However, when I returned to the post, the contents are gone. When I “edit post”, i can clearly see the text of the post, but in the live published post, all the text is missing.
So confused and frustrated… please help…
Please purge the cache a few times, also check if you don’t have an object cache -> https://forum.tagdiv.com/general-options-may-interfere-newspaper-theme/ -> https://kinsta.com/blog/w3-total-cache/#object-cache.
Also, please provide the link to your website.
I was able to figure it out by starting over from a brand new cloud template and also by utilizing the page caches.
However, changes don’t get updated unless you go into each post, and “update” it. Is this a bug?
For example, lets say I modify the single post template. It won’t show for any of the posts until i go into each single post, update it (with no changes) and refresh/clear objects.
This doesn’t seem like the right functionality because if you change something on the single post template, it would be unreasonable to go into each post manually and to do a phantom update by changing nothing and hitting ‘update’.
Does that make sense?
This reply was modified 4 years by
tagdivchick.
Seems this plugin creates an object cache file on the backend, so please delete the file -> https://supporthost.com/w3-total-cache/
