Post Editor spliting in Two Columns (Using Classic Editor)
I am using classic editor now with the NewsMag theme which I purchased just now. While editing any post or page, my post editor got split with two columns in which the right side is blank while I can work with the left side only. I don’t want to split my post editor with two columns.
Here is a screenshot link of the issue I am facing.
https://ibb.co/BsT21qj
I hope for the resolution from the NewsMag support staff.
Thanks in Advance.
In order to remove that line from post editor you need to go in wp-content>themes>Newsmag>editor-style.css
-> https://www.screencast.com/t/dM52p01U
Please check this similar topic bout how to remove the sidebar from post editor -> https://forum.tagdiv.com/topic/sidebar-on-visual-editor/
Having the same issue but the code only goes up to 1700.
This really needs to be a toggle on/off in theme settings.
Sorry, but for the moment there is no buttons for this, also now the WordPress editor is the Gutenberg editor, in short time the classic editor will be deprecate.
->https://wordpress.org/support/topic/end-of-life-for-the-classic-editor-two-years/
Thanks for your answer, but it’s not my problem, I didn’t explain myself well.
I would like to put two objects in the same column, in the same row.
I don’t need to remove anything.
In the red space I would like to put another object. Each should occupy 50% of the row
Hi mattinodiverona,
I do not quite understand, but I think that you want to edit a page, this can be done using tagDiv Composer add a new row and set the layout you need -> https://i.imgur.com/OL48lF3.png if you want to be 50% each column, then you can add a inner row -> https://i.imgur.com/yTPRFrZ.png
Hope this will help you!
