Post Format for TTS features
Hi Hello there,
We are implementing text to speech feature in our blog. Therefore, we would like to find solution for the issues below;
Our sample post with TTS – https://www.qbuzz.qnet.net/2022/09/26/qnet-sports-partners-business-lessons/
1 – How to create new post format to indicate post with TTS function. Right now theres 3 types of post format which is standard, video and audio. We would like to have our own custom listening icon on featured image as per sample here. https://ibb.co/PTxhhhP . Or can we tweak from audio post format? https://ibb.co/Z1SLmwq
2 – The post template for this TTS, How to make the listening option position on top of featured image. Currently, we add TTS iframe as the first section on post editor, featured image automatically projected on top of post front end.
Regards,
Yazz Hashim
If I understood correctly, you want to combine featured audio with featured image, there is no option for this. But it is possible to do it using CPT and ACF.
Hi Calin, we want to create new post format with custom icons displayed on featured image. Could be similar to video and audio post format icon.Problem with audio post format, its won’t showing the featured image on the post page.
The idea is, when visitor on homepage, they can see from the newsbox thumbnail, news post with listening features.
If I correctly understand what you mean, then you need to wait a few days for the coming theme update, then you’ll have the possibility to create the needed layout for the blocks and post templates using the new options that will be add for CPT and ACF.
