Post Grid Help
Doesn’t matter what I do Post Grid is not responsive at all and I can’t get it to work as in a grid. It doesn’t matter where I put it it doesn’t work. Your theme is bugged and it doesn’t work with all visual composer elements… I really need the post grid…
link example?
Tested Post Grid on a newly installed Newspaper theme and still it doesn’t work properly so I guess there is either a problem with the theme or the plug in. If you need more detail look at my newspaper thread.
Works perfect on all my sites, so not sure it’s a bug.
You don’t need to post in this thread for issues related to Newspaper – they are two totally different themes, with different CSS, different modules, different responsive layout, etc.
As I said I used a clean install of WordPress just the Newspaper theme and visual composer and it doesn’t work. It shows only one post per row and it is big as I showed you in the screenshot.
Right. This is the Newsmag theme forum, not the Newspaper theme forum.
So, the TagDiv support folks will answer your post *there* on Monday since you posted in both forums with the same issue. 🙂
Thanks Chris!
@kovachx
The newspaper theme hasn’t been tested with the latest version of the visual composer plugin so it could not work properly.
I’ve replied to you here: https://forum.tagdiv.com/topic/post-grid-help/#post-38405
Please post your issues about the newspaper theme in the newspaper forum section: https://forum.tagdiv.com/forum/newspaper/
Sorry for the inconvenience!
