in the Changelog for Version 9.1 (october 15th) there is this item:
new: Post Loop 2 element: Use this new element to display posts loop using other designs
If this is an Loop-Element i can add in the composer, im wondering where it is? I cant find or add it to my page. I want to open up the page with the Post Loop (incl. Pagination) and after that i want to add some focus content.
Best regards
Should be in the composer elements list – https://www.screencast.com/t/kgpB7GR2
Please check if the cloud library plugin is installed and active. Without it the loop elements will not appear
– https://forum.tagdiv.com/tagdiv-cloud-library-plugin/
