Hi, in the TagDiv composer the Post Loop blocks are missing the ability to filter categories like the flex blocks have. Also the FlexBlocks are missing the ability to load more or have indefinite loop.
There is also a bug where the Side bar in the TagDiv composer (using firefox) does not have a scroll bar and I need to drag to see more options.
The pagination number has only the elements posts loop and posts loop 2 -> https://i.imgur.com/RXAh0iM.png
The Posts Loops settings are divided into 5 tabs: General, Layout, Style, ADS and CSS. The Posts loop is a special block and doesn’t have filtering options.
Also, one of the options for pagination of the Posts Loop has the option for normal numbered and the flex blocks do not have this option.
The Posts Loop is automatically filtering the posts depending on the cloud template you set (for example on the category page there will be posted posts from that category).
The Flex Block, have the option for pagination to load more button and infinite load -> https://i.imgur.com/NTHv3g6.png
Also, there is no scroll bar, if you have a mouse with the scroll you can use it to scroll in tagDiv Composer.
Thank you, the flexblockwith pagination fixes my issue, however it wouuld be great if a scroll bar was added, I use a laptop with no external mouse and its difficult to scroll down
