Post Looping With Flex Blocks?
Hi-
Is there any way to loop the posts in one row together the same way a post loop works?
For example, in the screenshot it shows one of our sections but we would like for them to be a continuation of the same releases category. If we set them all as the same category, it repeats itself in each column.
We don’t want to add a normal post loop because they are not as visually appealing as the flex blocks.
Thanks in advance!
releases section
Hello @terahlynn!
A workaround there could be to use the offset feature in the second block. For more information about the offset feature, please check out this tutorial: https://forum.tagdiv.com/offset-feature/.
