Post Offset
Hello
On my site themasports.com I have setup 2 blogs with the following categories
Blog 1 -> Category Slider -> display 5 posts
Blog 2 -> Category Latest News -> Display 18 posts
I will like to exclude from blog 2 the first 5 post of category Slider. So I don’t get double posts.
Latest news includes post from slider too.
Any help?
There is an offset feature that you can use. This is useful when you want to display blocks with the same filtering but avoid duplicates
– https://forum.tagdiv.com/offset-feature/
There is also an unique articles option
– https://forum.tagdiv.com/unique-articles/
Note that this unique articles option should not be used together with any form of pagination, or it will create duplicates once loading other articles.
Hello! I am editing my site with tag div composer. I would like to try the Unique Articles feature, is there any incompatibility? Thank you!
@Agostina
There would be one note to consider when using the unique articles option
It should be used only if you do not use block pagination or other pagination it will generate duplicates on second/next page. This option would be useful when no pagination is used in the page (static page).
There is an offset feature as well
Useful when multiple blocks for example, are configured to display posts from the same categories.
