"Post Settings Panel" Not Showing, How to Enable It Again?
Hi, I’ve noticed in the last days that I don’t see when editing a post, the option to choose the style of the post. This is, the “Post Settings Panel” is not available.
I’ve checked in my Screen Options, but the point is that there isn’t the “Post Settings Panel” option to enable it.
How can I enable it again?
Hello aberniz,
Check your Screen option from post editor and make sure that your Post Settings are checked, like this -> https://www.screencast.com/t/35cjtD2UTe Also, if this option is not there, I suggest you making a new fresh install from scratch via FTP way clear all your caches and check the results. Also, you should check your system status parameters to be according to our documentation here -> https://forum.tagdiv.com/system-status-parameters-guide/
Hi Catalin, I’ve tried the first option but “Post Settings” is not available in my Screen Options. I don’t know why.
With regards to the second option: a new fresh install from scratch via FTP. Do you mean reinstall only the theme or the full WordPress site? I am very worried because I’ve been working on this site for 5 years now.
All the best,
Angel
Hello aberniz,
I think this is because the theme has not been properly installed, according to our documentation here -> https://forum.tagdiv.com/install-via-ftp/ First of all, try to make a full backup to your database and then clear all the caches and install the latest theme version with this method and check the results. Also, check the system status parameters to be increased according to our documentation here -> https://forum.tagdiv.com/system-status-parameters-guide/
I found the culprit: “Widgets On Pages” plugin.
I share this here, in case someone else has the same problem.
