I have two separate active instances / licenses for Newspaper theme, in one of them I was able to activate the Post Settings panel from the WP editor Preferences. But in another instance, this panel is missing as an option in the Preferences. Both instances have the same WP version, the difference is in the Newspaper theme version. The panel is visible as an option in version 10.3.6, but now in version 10.3.9.1.
So, is this a bug in version 10.3.9.1., or? Is it fixed in 10.4?
Cheers,
Sebastian
This topic was modified 5 years by
Sebastian.
I can confirm. Standard Pack does not effect this. Post Settings metabox is part of TD Composer (/td-composer/legacy/common/wp_booster/wp-admin/content-metaboxes). I never had SP active and had Post Settings metabox in posts. Now it’s just gone (not sure from which version). It’s gone in both classic and guttenberg editors.
Enabling Standard Pack does not activate Post Settings.
Please verify if you have this setting also enabled: https://prnt.sc/11x4kd7
Sometimes, the issue can be from a plugin conflict, that’s why, please deactivate ALL plugins except tagDiv ones, also if you are using a cache plugin, deactivate it, clear all cache and try again.
Hi Bettina,
The option is missing completely from the WP editor Preferences, please see: https://prnt.sc/11x861g. As mentioned before, in version 10.3.6 it shows up, but not in version 10.3.9.1.
I will update as soon as possible to Newspaper 10.4 and if still not working, deactivate plugins and come back to you with an update.
Cheers,
Sebastian
Hello @Sebastian!
This is weird because I verify also on both versions and it is still there.
Try with the update and verify if you have all plugins, WordPress up to date. If the problem is still there please send an email at contact@tagdiv.com and provide wp-admin, so we can investigate this issue. Also paste a link to this topic so we can easily identify you.
Let us know and we will gladly assist you.
I tracked it down by disabling plugins 1 by 1. The cause is compatitability with WooCommerce.
Disabling WooCommerce fixes it, but downgrading to previous versions doesn’t. Tested with:
WC 4.9.2 – not working
WC 5.0.0 – not working
WC 5.1.0 – not working
WC 5.2.0 – not working
WC 5.2.1 – not working
WC 5.2.2 – not working
WC 5.3.0 RC1 – not working
On Newspaper side tested with:
10.4 – not working
10.3.9.1 – not working
10.3.9.0 – not working
10.3.8 – not working
10.3.7 – not working
If Newspaper rollback updater also rolls back TD composer plugin, which is probably the real problem, than that would mean it’s not a recent update thing, but a major compatitability issue (I only recently installed WC, so I wouldn’t know).
Can you take it from here Bettina?
1. disable TagDiv Composer
4. install TagDiv Composer
5. activate TagDiv Composer
Also, make sure your WordPress and plugins are up to date.
Sometimes, the issue can be from a plugin conflict, that’s why, please deactivate ALL plugins except tagDiv ones, also if you are using a cache plugin, deactivate it, clear all cache(also from your browser) and try again.
We recommend using WP Super Cache plugin https://forum.tagdiv.com/cache-plugin-install-and-configure/
