i’ve just updated to the 8.0 version of newspaper and i have a problem changing the post template on the post itself while i’m writing it.
if i go in the theme panel i can set the one i want on default, but if i want to write a video post template, there isnt the option under the text space. there was, now is not.
how can i fix this?
NB: just to be clear, there isnt the “post setting” window under the post.
This topic was modified 9 years by
lucaapellegrini.
i’ve tried to delete and re-install the theme or to install an older version but it went in conflict with newer plugins.. so it didnt work.
i still dont see the “individual post settings” under the post that i want to write or modify.
Maybe the post settings got deactivated from the screen options. Please check if this is the case – https://www.screencast.com/t/osHEdRgFO
i tried to see if that was the cause.. but there isnt the option.
The post settings box should be present in the screen options on the post edit page by default. First try disabling all your plugins except the ones provided in the theme package, clear any caching installed and check to see if this has any effect. Maybe a plugin is causing this issue.
Lastly you could try a fresh theme install and see if that fixes it
– https://forum.tagdiv.com/install-via-ftp/
You were right! the plugin “widget on pages” was causing the issue. i Cleared the cache too and now the “post settings” is showing.
Thanks. Perfect Assistance.
