Posts Loop Column post offset not working
Hallo,
We’re trying to break our category page into smaller post loop sections to insert additional content after every 6 articles. While the preview works correctly, cloning a column and setting an offset for the next 8 articles, the live site displays the same posts as the first section.
We’ve also recorded a screen capture demonstrating the issue.
Could you please help us resolve this?
Screen record: https://app.screencast.com/UGRlL5r0pjhBL.
We do not recommend setting two posts loop on the same page/template because most of the settings from the first loop element will be inherited for the second one.
A workaround is to use flex blocks, and set the ads after each flex block and using the offset option -> https://forum.tagdiv.com/offset-feature/
For flex block, you should choose the current category“: Category – Current category ”special filter: https://forum.tagdiv.com/flex-block-settings-guide/
