Posts Loop doesn't work on mobile
It is impossible to access any articles on mobile with Post Loop.
http://www.NoFrag.com
Hello !
We have tested your website and everything seems to be working fine.
Please clear your cache, and retry.
Yes, because I removed the post loop block. Otherwise, the website doesn’t work on mobile.
I would like to know if you are aware of any issues regarding Posts Loop on mobile ?
Please, see here : https://nofrag.com/tests-homepage/
As you can see, on mobile, you can’t click on any articles.
  • This reply was modified 6 years by NoFrag.
Hello !
Please make sure that you have accomplished all the system requirements as in our documentation here: https://forum.tagdiv.com/requirements-for-newspaper/
