Posts per category module
I’m using module 5 for the homepage and categories http://appcomrade.com/category/app-reviews/iphone-apps/ if you look at the last row, there is only one post instead of three to fill up the row.
How can I manage the amount of posts per category/home page?
Nevermind I found out I just use the WordPress reading settings. However, I’m curious if there is a way to change the amount of posts per category page for individual pages.
Unfortunately the theme doesn’t supports that. It will have to be customized.
Radu from tagDiv
I see. Probably won’t have to do that anyways. Thanks.
