I’m new using this theme and I’m trying to configure it, but I don’t have much knowledge with programming.
I’ve downloaded the Travel Blog theme and I’m trying to put it to work but right now, among other issues, I cannot set my articles to show their images nor content…
They pretty much all look like this:
as seen here https://desbravandomadrid.com/2018/07/26/miradouro-parque-do-retiro/
I’ve already unabled all plugins since I’ve seen that Social WareFare was causing some troubles with other users…
FYI, I don’t have the same issue with pages, only articles, so I’m pretty sure it has tio due with some configuration I’m not doing well, but I cannot find it.
thanks in advance!
This topic was modified 8 years by
desbravandomadrid.
Also, I’ve seen that since I’ve installed Newspaper theme on my blog, Google Search Console gives me 50x errors for pretty much all pages, wich will damage my blog’s rankings if it stays this way.
This is the error 500 that appears on this article inparticular and on all the other articles as well…
This reply was modified 8 years by
desbravandomadrid.
desbravandomadrid.
There are guides that should be read when changing themes in a live website. Some here
– https://www.wpbeginner.com/beginners-guide/checklist-15-things-you-must-do-before-changing-wordpress-themes/
– https://www.wpexplorer.com/change-wordpress-theme/
Usually it is best to test everything locally before making the change live, also to use a maintenance mode to set everything up (to avoid ).
Currently the Newspaper theme seems inactive from what I can see. There is a tiny framework theme active.
Be sure to check the theme requirements as well for a proper functionality
Now as I write it seems the theme is active. I see the travel blog demo is installed. I will help you if you have any questions, the website looks alright from what I can see. Please let me know.
Hi Simion,
Thanks for your reply.
After a while I understood what the problem was: while installing the template, all the failes containing “ad” or “ads” were not being uploaded (didn’t understand why). I just reuploaded the template, making sure all the files were there and it is now working!
I have other questions, but I’ll open a new thread!
thank you anyway.
susana
