I installed w3 total cache and configurated like in document which in tagdiv support. After that i see postviews are not counted. then i installed wp-postviews plugin. It worked for me but all the statics were lost. so i decided to remove that wp-posviews. My pageview statics turned back normaly BUT now postviews are not count. Also i deleted w3 total cache and still not working. so all new posts views “0” and the old ones not counting..
What should i do?
my web. site: sanalsantiye.com
hi,
please go and delete the W3 Total Cache from the plugin directory manually. we have experience a problem with this plugin, even do we remove it it as still active.
here is a link to the documentation for posy views : https://forum.tagdiv.com/wp-postviews-post-view-counter-alternative-for-w3-total-cache/
I don’t know if you can still use your old page views number but hope this helps
Thanks for you message.
Radu A.
I really don’t like W3 TOTAL Cache plugin all it do is messed up your site,the best cache plugin to used is “WP Super Cache”.
When i first bought this theme postviews was working great,till the last update of this theme last week,i’m not using no W3 CACHE plugin are no postviews plugin,something was done to the update last week of this theme that make post views stop working…
hi,
someone trace this down :
https://forum.tagdiv.com/topic/stopped-working-after-the-upgrade-counter-view-article/#post-13452
Radu A.
