Prebuild website problem
I just made a clean installation of PHP8, wordpress and newspaper theme.
After importing the LONDON NEWS PRO prebuild theme template i cannot see the first page.
The console error i am getting is:
Uncaught Error at zones: 6(models) : 5(dom). The model does not match the content Current state has involved an issue. You could try an UNDO operation (CTRL+Z / CTRL+SHIFT+Z)
Also when i am editing the first page with tagv (loads slow) i am gettting the error:
As i can see this i have this error only on the first page and i repeat it is a clean installation.
Help me please.
Dedicated
Hello @mkioutsiouki2!
This issue has been already discussed here: https://forum.tagdiv.com/topic/errors-at-columns-elements-5/
Please make sure you did all the steps which I mentioned here: https://forum.tagdiv.com/topic/errors-at-columns-1models-0dom-the-model-does-not-match-the-content-curr/
Check this guide too: https://forum.tagdiv.com/general-options-may-interfere-newspaper-theme/
If this problem is not solved after that, then we need to take a look and see what happened there.
– admin url and credentials
Our team will take a look!
The problem is that your theme is not 100% compatible with PHP8.
Am i wrong?
Yes, we recommend version PHP 7.3 or 7.4.
