"Premium plugins" not installed
This is the message:
cURL error 7: Failed to connect to “xxxxxx.xx” port 80: Connection refused
How can I solve the problem?
I believe the hosting provider should be able to provide assistance with this, could be a firewall setting or server configuration issue.
You can also install the theme plugins manually, they are provided in the full theme package, plugins folder – https://forum.tagdiv.com/whats-included/
This should work fine, but I still think this issue should be mentioned to the hosting provider.
Let me know if you have more questions.
