Print post – adding blank column
Hi guys,
When I click the print button, it adds a blank column down the right side of the post.
See here for an example: https://defenceofthetruth.com/en/2021/03/the-preparation-for-the-permanent-home/
Please help.
Steve
After clicking the print button, you can set up the margins custom and you can center the page like this: https://www.screencast.com/t/zrlYKlmsIGrj
Hope that helps you!
Yeah that could work, but is cumbersome. Wondering why it doesn’t just fill the page like the website actually displays.
It is implemented like this, which design to display when you print in the file called “print.less”. If you want to modify that, then this will require custom work which is not covered by the support team.
Hi! if don’t mind can you post your solution to implement a print button. Many thanks.
Hello @virjik!
Please note that customization is not covered by the support team: https://forum.tagdiv.com/newspaper-theme-support/
For customization and other services you can contact our custom work team here: https://tagdiv.com/premium-customization-services/
