Problem after update
Hi, I update Newspaper to the newest version and when I produce new post and won’t see it before publishing I get this information:
Warning: require(/home/platne/serwer15223/public_html/lchfdieta.pl/wp-content/plugins/td-standard-pack/Newspaper): failed to open stream: No such device in /home/platne/serwer15223/public_html/lchfdieta.pl/wp-includes/comment-template.php on line 1532
Fatal error: require(): Failed opening required ‘/home/platne/serwer15223/public_html/lchfdieta.pl/wp-content/plugins/td-standard-pack/Newspaper/’ (include_path=’.:/usr/local/php56-fpm/lib/php’) in /home/platne/serwer15223/public_html/lchfdieta.pl/wp-includes/comment-template.php on line 1532
I check with my webbhotell and they can help. There som wrong with the theme and I need help
Hi, I update Newspaper to the newest version and when I produce new post and wanted see it before publishing I get this information:
I check with my webbhotell and they can`t help. There som wrong with the theme and I need help
Hello !
Please send us a screenshot of your System Status Tab and make sure that all the requirements are met as you can see here: https://forum.tagdiv.com/requirements-for-newspaper/ ; You will have to first start looking for a plugin conflict. please deactivate ALL plugins except tagDiv ones, also if you are using child theme or cache plugin, deactivate them, clear all cache and try again.
Also you can try and remove and re-install the tagDiv Composer plugin.
Let us know the results.
