problem after updating theme
when I am on home section, then I click “edit with tag div composer” nothing happens and te spinner keep loading with out showing anything
Hi contacto Ehecatl, please make sure that you are using last theme version Newspaper v10.3.7 and you have set all the theme requirements as in our guide – https://forum.tagdiv.com/requirements-for-newspaper/
If the problem is still persisting, also is possible to have some plugins that are not compatible with our theme and creates this problem, please deactivate ALL plugins except tagDiv plugins (theme plugins), also if you are using child theme or cache plugin, deactivate them, clear all cache and try again.
Let me know the results!
