hi, i have this error in coosole when try to edit
Failed to load resource: the server responded with a status of 403 ()
load-scripts.php?c=1&load[chunk_0]=jquery-core,jquery-migrate,utils&ver=5.7:5 JQMIGRATE: Migrate is installed, version 3.3.2
deprecated.min.js?ver=be1d4376501c21d85ba98dd28ca2d7ea:2 wp.editor.InspectorControls is deprecated. Please use wp.blockEditor.InspectorControls instead.
c @ deprecated.min.js?ver=be1d4376501c21d85ba98dd28ca2d7ea:2
load-styles.php:1 Failed to load resource: the server responded with a status of 403 ()
Hello !
Please send us a screenshot of your System Status Tab and make sure that all the requirements are met as you can see here: https://forum.tagdiv.com/requirements-for-newspaper/ ; You will have to first start looking for a plugin conflict. please deactivate ALL plugins except tagDiv ones, also if you are using child theme or cache plugin, deactivate them, clear all cache and try again.
Also you can try and remove and re-install the tagDiv Composer plugin and please send us a link to your website in order to take a look.
Let us know the results.
