chech my article
and check the ads
https://yourcatsinlife.com/15-cats-doing-a-better-job-of-modelling-than-their-human-counterparts/
Hello adam21s,
I have inspected your website and I saw that you have some problems with the sidebar and ads on the articles posted. I suggest you make a new clean install from scratch via FTP way, clear all the caches and check the results. -> https://www.screencast.com/t/UQGsyd5z
If you are using some untested plugins, remove all of these and leave just only the required plugins to active and check the results.
