Problem in footer widget
Hi, in my site I have three footer widgets in the footer. But in the widget section in the wordpress panel, under the tab footer1 fotter2 and footer3 are empty.
screenshot1: https://ibb.co/Y7WQNSF
screenshot2: https://ibb.co/f42ndbq
screenshot1
screenshot2
  • This topic was modified 7 years by zklid.
Some of footers templates are custom made and you can not remove the blocks from it, only add new ones, that’s way the footer widgets are empty -> https://www.screencast.com/t/vFtmLxpxo6
Footer templates -> https://forum.tagdiv.com/footer-templates/
